Sound and Vibration
LabVIEW Fatigue Analysis
LabVIEW Fatigue Analysis consists of a set of VIs for stress-life based fatigue analysis. Analysis functions include peak and trough detection, rainflow cycle counting, rainflow histogram matrix, load spectrum estimation, S-N curve generation, and stress-life based damage estimation.
These VIs are designed for use in each step of the stress-life based fatigue analysis process.
Refer to NI developer zone article Fatigue Analysis in LabVIEW for more details about fatigue analysis concept.
You can find the installer from the following attachment. After installation, you will find a new Fatigue Analysis subpalette locating in LabVIEW functions panel>>User Libraries.
*Note that to apply these functions, you need to install LabVIEW 8.5 or later
Message 1 of 18
(38,775 Views)
Laiwei -
First I'd like to thank you for your contributions to the site regarding Rainflow and fatigue analysis - your writeup has proven very valuable to us in our analysis.
We've used the rainflow counting example originally posted by NanxiongZhang.  We've lightly modified it for our purposes and it seems to be working well.
We want to use the results in a test report we are preparing - however we're pretty sure we're going to be asked for V&V (valid and verifiable) documentation for this VI.  You've mentioned multiple places that this VI conforms to the ASTM 1049 standard - we were wondering if you have any documentation that proves this?  Any help you could give us would be greatly appreciated.  We're planning on uploading our finished VI to the community when we're finished - we've added a few easy things like a matrix output for data analysis and signal selection.  Also had tech. support help us lighten the memory load so we can put a lot of datapoints through it without problems.
Thanks in advance!
Message 2 of 18
(23,139 Views)
Hi Milon,
Although the rainflow cycle counting VI is implemented according to ASTM 1049 doc, currently we have no any formal/official verification for the VI, because the startup kit is not a formal NI product now.
If need any other tech support, feel free to let me know.
Regards
Lai Wei
Message 3 of 18
(23,139 Views)
Regards
Brad
Message 4 of 18
(23,139 Views)
There is shift register in the VI, which can continuously process block data.
Message 5 of 18
(23,139 Views)
Lai Wei,
do I need to use some kind of "mean stress correction" or it's already included in the damage estimation?
Thank you!
Caio Scozzafave
Message 6 of 18
(23,139 Views)
With the internet of things, and pipelines an important infrastructucture, perhaps the fatigue analysis tools might be useful for stress monitoring in stationary infrastructure.
When will the Fatigue Analysis toolkit install in LabVIEW 64bit?  64bit LabVIEW is much better at handling Big Analog Data(tm) data sets and large analysis.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
Message 7 of 18
(23,139 Views)
I know scozza's question is very old, but I had the same question. I dug into the VIs and found that it does use a Goodman mean stress correction factor VI called "vfa_Sa to Sa(R-1) (Goodman).vi".
Message 8 of 18
(23,139 Views)
Hello Nick,
Thanks for the answer! Although it is old, It still necessary for me
Best wishes,
Scozza
Am 23.12.2015 17:32 schrieb "nickbike" <web.community@ni.com>:
NI Community <https://decibel.ni.com/content/index.jspa> LabVIEW Fatigue
Analysis new comment by nickbike
<https://decibel.ni.com/content/people/nickbike> View all comments on
this document <https://decibel.ni.com/content/docs/DOC-8215#comment-46517>
Message 9 of 18
(23,139 Views)
I used the rainflow counting algoritm VI and started checking the programming after getting odd results.  I think there is an error in the sub VI where it puts the value and corresponding cycle counting in the amplitude and mean array. In the calculation of the row and column where the value should be inserted, the results of  ((value - min. limit )/ delta of the class) is rounded to the nearest integer although I think it should be rounded to the lowest ??
Message 10 of 18
(23,139 Views)
