Sound and Vibration
VI pallette for reading mp3 files
Hello concerned,
Can somebody let me know the VI pallette for reading the Mp3 file. I want to get the mp3 file and filter it for different operation it to implement an audio equalizer with it.
Regards
(23,536 Views)
The best way to load an MP3 file into LabVIEW would be through the USI plug in. I hesitate to say it would be the only way. (Lots of ways to do things in LabVIEW)
http://zone.ni.com/devzone/cda/tut/p/id/11951
Is a very high level walk through of using a data plugin.
You will need to run the audio USI plugin before doing this.
http://zone.ni.com/devzone/cda/epd/p/id/44
I don't know why the documentation implies it only works for .WAV files. I have used it to open the kalimba mp3 file that ships with Windows.
I have not made any functionality yet beyond just pulling up the file.
I would encourage you to have a data loading phase and then manipulate the data. Trying to stream data from the file as you manipulate may be difficult to implement.
I will post further code if i can get anything like a functional equalizer running.
(14,534 Views)
Yes, this works.  Here's what I did below.  You can get it to show up as waveform data, then you can filter it as you wish.
(14,534 Views)
very usefull
(14,534 Views)
Btw, if someone is having a problem with the x-axis formatting strangely here's what you can do:
Double click on the "Read Data" Express VI. In the bottom right hand corner, where it says "Output data channels as:" Choose something other than "Array of Waveforms" or really anything other than Dynamic Data Type. Then you can format the x-axis as needed.
Zofia
NI Technical Support Engineer
(13,117 Views)
Yes. you can.
First you need convert mp3 to simple data.
Then put it in LabVIEW player format Y,
LabVIEW format is single channel data and make a array.
So the key is convert to wave format.
(6,388 Views)
The format has problem. This open not support mp3 format.
(6,360 Views)
