Home
Community
Discussion Forums
Additional NI Product Boards
Switch Hardware and Software
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Are there labview drivers for setting parallel port pins hi or low?
bradvonseg
Member
01-22-2003
02:06 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
My application is to open or close relays and I was wondering if the parallel port could be used in this application by setting the pin voltages high or low to control the relays.
0
Kudos
Message
1
of 2
(8,445 Views)
Reply
Re: Are there labview drivers for setting parallel port pins hi or low?
Randy_H
NI Employee (retired)
01-23-2003
10:22 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Please see the following document from the NI web site on dealing with the parallel port:
Using the Parallel Port in LabVIEW
Randy Hoskin
http://www.ni.com/ask
0
Kudos
Message
2
of 2
(8,445 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
