Switch Hardware and Software
Multiple connections within a Route in Switch Executive?
Hi. I was just giving a seminar on TS and SE and one of the questions that came up about SE was whether you could create a Route that connects one source to a whole bunch of other channels. I'm pretty sure this is not possible. In particular, what he wants to do is connect his Ground to 250 other lines. I think the only way to do this now is to create 250 Routes from the lines to Ground and then put them all into a Route Group. Even doing this, SE is going to complain because he will be using the same Configuration Channel for each Route.
I guess my questions are:
Is there a better way to do this?
If not, then can we bypass the error checking that won't allow us to create a Route group with Routes using the s
ame config Channel? Also, if there isn't a way to do this currently, then I think we should make a suggestion CAR asking to be able to easily create a Route or Route Group that consists of a single Source going to muliple destinations.
Thanks for your help.
(6,865 Views)
Here are my 2 cents... Instead of connecting the source to a column, connect it to a row and set up the appropriate configuration in SE so that it knows that you will be using a source. In this way, you will be able to connect more than one column to it.
Keep up the good work!
Annette
(6,865 Views)
To confirm Annette's thought, if you connect your source to a column, you can create a route between this column and a row, and 250 routes between the same row and other columns. You will not get any errors.
You can also connect the source directly to a row, and create 250 routes between this row and 250 columns.
You do not need to use any configuration channels.
(6,865 Views)
