07-06-2006 09:14 AM
07-07-2006 04:29 PM
07-10-2006 09:25 AM
07-11-2006 05:06 PM
07-11-2006
05:45 PM
- last edited on
10-06-2025
07:27 PM
by
Content Cleaner
Hello NeuralJ,
Your PCI-6025E device has 32 individual digital I/O lines, grouped into 4 ports of 8 lines each (port0, port1, port 2, and port3). It is one of the few E-Series DAQ devices with extended digital I/O lines, and because of this has different current sourcing capabilities depending on the port used.
Your PCI-6025E connects to the BNC-2110 terminal block using a 68-pin cable. The BNC-2110 breaks out these 68 lines on your DAQ device to BNC connection and screw terminals. The BNC connections are used for analog input, analog output, and a few other special connections. The screw terminals provide access to the first 8 of the 32 digital lines (port0) and other specialty lines called PFI lines. The screw terminal labeled P0.0 through P0.7 provide access to the digital lines of port 0 on your 6025E. You'll need to connect the lines of your relay between one of the digital line screw terminals and one to a D GND (ground) terminal. You can then use LabVIEW or some other programming environment to toggle that digital line between low (0V) and high (5V) in order to turn the relay on or off. Within your programming environment, you can write a program to toggle each line individually, so just pick one digital line and use that. For starters, you can use the test panels in Measurement & Automation Explorer (MAX) to toggle the digital lines to see if everything is connected properly. Within MAX, find your device under Devices and Interfaces > NI-DAQmx Devices, right-click on it and select Test Panels, click on the digital I/O tab, set the lines to output, and toggle them with the switches on the test panel.
I hope this information helps and let us know as the questions come up![]()
Travis G.
Applications Engineering
07-14-2006 10:23 AM
07-17-2006 07:04 PM
07-18-2006 08:46 AM
07-18-2006 08:46 AM
07-21-2006 03:16 PM
