Switch Hardware and Software
Can I use a PCI-6520 Card with LabVIEW Ver. 5.1?
We have an older ver. of LabVIEW, namely ver. 5.1, which has been working fine, in our simple motor-controller application. We wish to implement a new output control function using the NI PCI-6520 (electro-mechanical relays) board, which seems to fit the bill. Question:  Can we use this I/O board with the ver. 5.1 of LabVIEW at all?  If "yes", do we need to procure new additional software module(s) or drivers, to interface properly to that I/O board?
Thank you very much for the assistance!
Best Regards,
tdoptro
(7,050 Views)
Hello tdoptro,
The PCI-6520 is supported only by our NI-DAQmx driver, which is not compatible with LabVIEW 5.1.  NI-DAQmx can only be installed with LabVIEW 7.0 or higher, so if you want to use this board, you would need to upgrade your version of LabVIEW.
(7,034 Views)
Hello Jarrod,
Thank you very much for the information. I will look into an upgrade.
Best Regards,
tdoptro
(7,031 Views)
