Switch Hardware and Software
Issues with Virtual Channel Configuration
I'm trying to set up the virtual channels on a new PXI system using MAX. I can manage this with no problems (thus far) with the Digital I/O channels on their respective cards, however I have two issues with regards to the Analogue channels.
Firstly - I receive an error 200077 when I set the scaled range on a channel to be 0 to 500 mV with the original voltage being -10 to 10V. It is fine if the scaled range has the lower bound as a negative, such as -500 for example, but doesn't seem to like me setting the range to be wholly positive, informing me that a requested value is outside the allowed range (allowed range in this case being 0 - 500 and the requested value -10)
Secondly - when I attempt to test any of the analogue channels (even those with an acceptable scaling range) I receive an 88617 error, and am informed that perhaps the drivers on the controller and remote system are mismatched, although I've checked and they do match up. I haven't found any reference to an 88617 error on the forums or elsewhere, can anyone shed any light on this.
Any assistance or ideas would be appreciated,
thanks
Will
(6,768 Views)
Hi Will,
This is a duplicate post, I have posted a response to this on the other thread
http://forums.ni.com/ni/board/message?board.id=250&message.id=24213
Regards
Hannah
NIUK & Ireland
(6,739 Views)
