10-07-2016 10:13 AM
I have physically removed several unused switchblock cards from the 2800 carrier, they show up with red X's in the MAX configuration tree, but there is no option to delete or remove the devices from the tree. The online help says to right click the device name and select Delete, but there is no Delete option in the menu.
Solved! Go to Solution.
10-07-2016 10:26 AM
Bholsinger,
Are you trying to delete the Cards (named something like "SwitchBlock1/1") or the Devices (named something like "SwitchBlock1Dev1")?
Perhaps you need to click the Carrier that it lives in, click configure, and update the combinations to omit the physically removed cards?
10-07-2016 10:30 AM
I also tried going to Switchblock Configuration, but there again is NO option to delete the devices from the config. I have already physically removed the blades/cards/modules from the carrier.
10-07-2016 10:50 AM
Hello bholsinger,
Which version of NI-SWITCH and/or NI-DAQmx are you using?
10-07-2016 10:53 AM
Ni-daqmx 15.5.1
Ni-switch 15.1.1
10-13-2016
10:14 AM
- last edited on
05-29-2026
07:51 PM
by
Content Cleaner
Hi Bholsinger,
Thank you for bringing this up to us.
We've filed an error report (CAR# 609019) to address and fix this.
I can't guarantee when it will get taken care of, but it's on the dev team's radar.
In the mean time we do have a couple workarounds for the issue:
*If you have configuration data (custom device names, scales, tasks, etc.) I highly recommend exporting your configuration data (File>>Export). You can then edit the file to remove the SwitchBlock elements you don't want. Then on system restart you can import the file (File>>Import). Otherwise you'll need to recreate all of your custom data after resetting the database.
I'd personally recommend the first option as it is the most straightforward, but please let us know if either of these options work for you. I know that they are not ideal solutions, but hopefully you'll find them satisfactory in the interim
Best Regards,
Chris
