Switch Hardware and Software
Current status of the 1127!
I got the Niswitch 1127 recognise in MAX but when i use MAX test application (soft front panel) it returns the following error:"initwithoptions Failed".
I'm using Traditional DAQ devices that it's the recommended for the 1127.
(6,549 Views)
Before using the ni-switch soft front panel make sure you test the chassis in MAX. When you open ni-switch soft front panel make sure you select the correct 1127 if you have multiple ones.
What is your switch controller?
If the chassis is verified in MAX, the soft front panel should work.
(6,549 Views)
