Switch Hardware and Software
Where can I get the Nidaq functional reference guide?
I need to get the function definitions to access the PCI-DIO-96 via
Delphi. I've tried to find the manual and cannot. Could someone
please point me to where I can get this information?
Tim
(6,844 Views)
Tim,
The NI-DAQ functions are documented in the NI-DAQ Function
Reference Help
. After installing NI-DAQ, this resource is
available in the following location:
Start >> Programs >> National Instruments >> NI-DAQ >> NI-DAQ Function
Reference Help
The NI-DAQ functions that are supported by the PCI-DIO-96 are the
following:
Config_DAQ_Event_Message
DIG_Block_Check
DIG_Block_Clear
DIG_Block_In
DIG_Block_Out
DIG_In_Line
DIG_In_Prt
DIG_Out_Line
DIG_Out_Prt
DIG_Prt_Config
DIG_Prt_Status
DIG_SCAN_Setup
Get_DAQ_Device_Info
Get_NI_DAQ_Version
Init_DA_Brds
Good luck with your application.
Spencer S.
(6,844 Views)
Where to find this MIGHT have been referenced in the user's guide!
(6,844 Views)
