Switch Hardware and Software
Eurotherm 808 -- Can not locate instrument
I attempting to connect a Eurotherm 808 to my computer to use in Labview. I tried to connect the eurotherm directly to my computer directly via an SRS 232 (d9 pin) connector. Then use NI MAX to identify it.
I get the following image when I look at the Test panel. I believe the computer acknowledges something in the port because I cannot access the 'VISA Test Panel' when the instrument is unplugged/disconnected. When I do access the 'VISA Test Panel', the 'View Attributes' page tells me there is an 'Invalid Property Value' and I get the error message on the right pannel.
I've additionally tried to connect directly to a NI USB 6221, then identify via NI MAX, but also could not get it to recognize the port. No error messages in this route.
Any insight would be appreciated.
(1,174 Views)
Hello
How can you connect the eurotherm 808 connect to software and hardware computer?
(922 Views)
How to set the each zone temprature of Eurotherm 808 ? I am using it in Chemical vapor deposition furnace.. how eurotherm 808 connect to software and hardware computerfra.jpg
(920 Views)
