Switch Hardware and Software
How can I control Startup conditions in Labview?
I am using LabView to control several solenoid valves. When the LabView project opens, the solenoid valves are opened. As soon as the program is run, they close. I attempted to prevent them from opening by making the program run on startup, but the valves are still opened for a moment. This causes a potential danger and needs to be avoided. Any suggestions?
(6,404 Views)
Rachel,
What switch are you using and which API, NISWITCH or NIDAQ?
(6,403 Views)
