Switch Hardware and Software
Problem with Relay Mulitplexer Module Programming
Sir,
I loaded a following vi from example code library.I am using Relay Switch Card(NI 2503) and DMM(NI 4060) for Measurement.
Switch_SCANNER_with_DMM_Handshaking.vi, This vi is same as shown in Relay Switch software manual.
In this vi, It demands niDMM configure Measurement.vi and niDMM Configure Meas Complete Dest.vi
These vis are not in old and new driver of this module, I used niDMM configure.vi and
niDMM Configure Meas Complete.vi instead of that vi by seeing same node.
Then after execution of program , Its showing error in niDMM Configure Multi point.vi
Error Code is : BFFA0010
Because in diagram there is shown TTL1 in sample trigger node and in given vi (niDMM Configure Multi point.vithere is
only one option shown Immediate.
so please solve these problems and how these vi which are not with driver, will be used or from where i can download these vi.
Jitendra
HAL Korwa
Message 1 of 1
(7,054 Views)
