Switch Hardware and Software
How to use Programmable resistance 2720
I am using and programming with PXI-2720. Could I set the resistance value in CVI program?
I put the niswitch.fp in my project.
Do I need to control all relays for making 30ohm( example value) at my program?
Could you help me if you have any sample codes or references?
I have used "272x Reference VIs" for LabView.
I am looking for similar instrument driver for CVI.
Thank you,
Insuk
(7,206 Views)
Maybe I need to use the following function:
niSwitch_InitWithTopology (, NISWITCH_TOPOLOGY_2720_INDEPENDENT, VI_FALSE, VI_TRUE, );
Thank you,
Insuk
(7,205 Views)
Accepted by topic author momo2013
I think I get the way how to calculate.
Thank you!
(7,198 Views)
Hey Momo,
Certainly let me know if you have any questions.  To answers your initial question, yes, you'll need to manually configure each relay if you're not using LabVIEW, as the native driver works at the relay level.
-John Sullivan
Problem Solver
(7,193 Views)
Hi
just see my commends here.
http://forums.ni.com/t5/LabWindows-CVI/ni-272x-modules-on-CVI-program/m-p/2715043/highlight/true#M65...
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(7,093 Views)
