Switch Hardware and Software
PXI-4021 Memory and Sanitization
I am trying to determine what memory is contained inside the PXI-4021 to include type of memory and size. Also how do you sanitize the device if memory is present.
(6,841 Views)
The PXI-4021 has the following nonvolatile memory:
U32 - AT28C64B-15JU
U15 - AT28C256-15JU
Sanitizing the device requires removal of U32 and U15.  Note that the NI-4021 will not work with U32 and U15 removed.
-John Sullivan
Problem Solver
(6,832 Views)
Thanks for the quick response.
Is this memory user modifiable? and what information can be stored insdie the EEPROM.
Thanks again. CT
(6,806 Views)
The EEPROM holds the firmware for the device and is not user modifiable.  However, since it is just a standard EEPROM, it's possible that an educated person could change the personality, so if you're trying to meet government standards, NI recommends removing all nonvolatile memory storage elements.  Once you do that, the module will no longer work.  If you have a 'golden' 4021 that you know hasn't been tinkered with, you could read the EEPROM off of it and then comparte that data to the data on the suspect 4021.  If the data is different, then you could overwrite with the 'golden' data.  The 4021 is simply a communication adapter that allows PXI to communicate with SCXI, but if you've been tasked with sanitizing a product, overkill is the name of the game.
-John Sullivan
Problem Solver
(6,797 Views)
Thanks for the help.
(6,792 Views)
