Switch Hardware and Software
Is there a way to merge two virtual devices created with switch executive?
Can both be exported and then just copy the the xml code into one xml file and then import this new configuration? I tried doing this with notepad but it didn't work. I suspect that an xml editor is needed. If I can't do this I will have to retype at least 300 channel names and comments. Any help would be appreciated.
kph
(6,426 Views)
I am afraid to tell you that there is no easy way to merge 2 NISE configurations at the moment. In future version of NISE, there is going to be a way to merge 2 XML files (from the exporting function) and import the combined file to a single NISE configuration.
(6,421 Views)
