 ahmdhazimm
			ahmdhazimm
			03-16-2023 09:35 PM
Hi, could any help with this issues.
i noticed that my pc that running with Windows 10 always had this issues.
I already reboot the pc and reinstall the labview and the driver.
What im missing?
- TestStand's Error Message:
An error occurred while performing the switch operation 'Disconnect All' for the following device 'XCONN11'.
Could not perform the switching operation:
Details:An error has occurred while attempting to access device 34980A
VISA error = The connection for the given session has been lost.(Error = -2147483648)
 santo_13
			santo_13
			03-18-2023 07:53 AM
Looks like some serial communication error. How do you connect the 34980A to the PC? if you use USB, do check your PC power settings to ensure it doesn't turn off the USB when idle.
03-24-2023 07:12 PM
Im using Lan connection. Other instruments don’t encounter the issues…only the 34980A.
