Switch Hardware and Software
Looking for cable and screw terminal block to work with PXI-2568
I'm having a hard time finding an appropriate and cost effective connectivity solution to connect to the PXI-2568 62-pin dsub connector. The dsub form factor is of course quite common, but the 62-pin configuration appears to be very rare. Raw connector bodies seem to be  in good supply, but I've found only one vendor which sells a complete cable assembly, albeit, at a very high price. Has anyone found a decent supplier?
(7,655 Views)
NI does not make a terminal block for the 2568. The front panel connector 62-position D-subminiature can be obtained from any manufacturer. I did a quick "google" search for "62-pin D-sub connector" and multiple results are returned with different vendors. You can give it a try and find the best price/quality connectors that fit your need.
(7,634 Views)
Bruno,
Visit the following link at L-COM. They have a cable with 68 position D-sub for $45. You need to verify that the rating of the cable is compatile with your application (signal level).
http://www.l-com.com/productfamily.aspx?id=1024
Guy Ferraro
Switch Product Support Engineer
NI - USA
(7,628 Views)
