Switch Hardware and Software
NI Switch Executive generating errors during validate
After installing NI switch executive, when the default SwitchExecutiveExample is validated following error message is generated. Getting the same error when I try to validate third party IVI driver..
Validating SwitchExecutiveExample ...
 Testing IVI Configuration ... Error:
     An error has occured while attempting to access device SampleMatrix1
Primary Error: (Hex 0xBFFA2001) Invalid path string.
Secondary Error: (Hex 0xBFFA200A) Invalid path string.
Elaboration: AT11_20
 Testing Routes ...
  Testing ArbToInput ... Error:
  Testing DCPowerToUUT_Vcc ... Error:
  Testing DIO_0ToUUT_IO_0 ... Error:
  Testing DIO_1ToUUT_IO_1 ... Error:
  Testing DIO_2ToUUT_IO_2 ... Error:
  Testing DIO_3ToUUT_IO_3 ... Error:
  Testing DMMToUUT_Vcc ... Error:
  Testing ScopeToOutput ... Error:
 Testing Route Groups ...
  Testing DIOToUUT ... Error:
  Testing FreqRespWithIO ... Error:
  Testing FreqResponseTest ... Error:
  Testing PowerUUT ... Error:
Validation test failed.
(8,423 Views)
Papaiha,
It sounds like the error is caused by a failed IVI logical name lookup. SampleMatrix1 and 2 are installed by the installer and the necessary IVI infomation is created after you first reboot. If the installation has been succesful and after you reboot you should be able to validate SwitchExecutiveExample wihout errors. Something got corrupted in the installation process.  At this point I would remove NISE and reinstall.
What version of NISE do you have?
Guy Ferraro
Switch Product Support Engineer
NI - USA
(8,408 Views)
Papaiah,
Does your third pary IVI driver come with an installer that might overwrite the installation of VISA on your system?
I would try installing Switch Executive on another computer without the third pary IVI driver and try validating the SwitchExecutiveExample.  Alternatively, you could try uninstalling both the 3rd party IVI driver and Switch Executive from your computer and then reinstall Switch Executive only.
Thanks.  Let me know what you find.
Travis W
(8,408 Views)
Reinstalling the Switch executive helped in passing the validate of default switch configuration, However third party IVI driver is still failing validate. While I was re-installing switch executive 2.0, I got the following error couple of times:
Error 1714: The older version of IVI Engine2.0 cannot be removed.
After installation is complete, before finish button message was: Installation failed please correct the problm and try again.
There are two items on my computer which I cannot uninstall:  NI IVI Engine 1.83 and NI labview Database connectivity tool set. Theye might have got installed during my previous version installations, Now I couldn't locate those CDs.
Please let me know if there is a way out, other than rebuilding the PC...
Papaiah Kummari.
(8,397 Views)
PK,
Are you running under Windows XP?  Does the IVI Engine show up in MAX under your software tree?  If so, does that version match the version listed in Add/Remove Programs?
Check out this KnowledgeBase entry.  The IVI engine could be a part of a LabVIEW 6 installation.
Let me know if this helps out at all...
(8,352 Views)
