Switch Hardware and Software
Why 'Switch Initialize error with LabView, SCXI-1001 chassis with 1128 modules?
Software = 'Dual DMM and Switch Scanning.vi' as an executable file with LabView Runtime v6.02.
Drivers = DAQ V6.9.3, DMM V1.6, Switch V1.6, VISA V2.5.2, MAX V2.2, MXI-3 V1.15.
Hardware = SCXI-1001 chassis with 1128 Switch Matrix Modules and a High Voltage Analog Bus (HVAB). This chassis is connected to a PXI-1052 Combo Chassis containing (2) 4060 DMMs, MXI-3 Control Module and 1128 Switch Matrix Modules.
Error = niSwitch Initialize.vi ERROR: (HEX 0xBFFC0011) Identification query failed.
Has anyone had this error with either a PXI-1052 Combo chassis or a 1001 SCXI chassis?
What resolved the problem?
Display Tech.
(6,789 Views)
Are you able to perform just switch scanning without DMM and without errors? Can you isolate to switch and see what is causing the problem. If it gives same error with NI-SWITCH and without NI-DMM, then please post code.
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
(6,778 Views)
