Switch Hardware and Software
NI SwitchExec with 3499 and IVIDriver
The system is already defined. So if the switch-instruments (34970) dont work with NISE we have to use an other method.
Thank you very much for your fast help & information.
Message 11 of 12
(4,103 Views)
I am facing a similar problem. The difference is that I am trying to use the IVI driver with LabVIEW. I tried the fix provided in the first reply to specify the driver setup as "slot1:N2272A:1". Note I used N2272A because this is what I see on the instrument when I see the settings manually. Am I doing it right? If there anything else required to make it work using LabVIEW.
Harpreet
Message 12 of 12
(4,034 Views)
