Switch Hardware and Software
NISE 3.6 Mixing Switching Capabilities/Route Broken
Good morning,
I have an issue whereby I have used hardwires to connect one pole of two switches to each other.  The other pole end of each switch is connected to a UUT pin (UUTP1 and UUTP2).  The switches are different items of hardware.  I would expect that if I connect UUTP1 to the hardwired pole, the route would be found, and it is.  But if I connect UUTP2 to the same hardwired pole, NISE reports the channel 'does not satisfy new constraints'.  I assume the reason is the card route specs are different.  Is there a way to ignore the error and allow the connection across different hardware switches?
Steve
(3,623 Views)
This may help explain my issue...(if it's no too small!)
(3,599 Views)
Let me understand your implementation correctly,
  1. You connect SW1 COM -> SW1 NO - it works
  2. You connect SW1 COM -> SW2 NO - it throws an error?
If you expect SW1 COM -> SW2 NO to work, it will not, because you've externally connected SW1 COM and SW2 COM and SE will not be able to consider that.
NO (Normally Open)
Santhosh
Soliton Technologies
(3,547 Views)
