02-22-2021 07:12 AM
Good morning,
I have an issue whereby I have used hardwires to connect one pole of two switches to each other. The other pole end of each switch is connected to a UUT pin (UUTP1 and UUTP2). The switches are different items of hardware. I would expect that if I connect UUTP1 to the hardwired pole, the route would be found, and it is. But if I connect UUTP2 to the same hardwired pole, NISE reports the channel 'does not satisfy new constraints'. I assume the reason is the card route specs are different. Is there a way to ignore the error and allow the connection across different hardware switches?
Steve
02-22-2021 08:58 AM
This may help explain my issue...(if it's no too small!)
03-03-2021 01:16 PM
Let me understand your implementation correctly,
If you expect SW1 COM -> SW2 NO to work, it will not, because you've externally connected SW1 COM and SW2 COM and SE will not be able to consider that.
NO (Normally Open)
