Switch Hardware and Software
PXI 2567 (64 Ch Relay Driver) - NI Switch GetStatus
Hi all,
I am working on a circuit board which has relays controlled through the PXI 2567 64Ch relay driver. I would really appreciate if someone could help me create a VI to fetch the status of all the relay channels (either ON or OFF) when executed once. This would significantly reduce my debugging time.
There's this NI Switch - Get Status function which supports such an operation. I am trying to figure out on how to use it. Any help would be appreciated.
(5,108 Views)
Hi sjadav, what if you use the niSwitch Get Relay Position.vi, you just set the relay name and you get the status
Take a look at the palette
(5,076 Views)
I'm not familiar with NI Switch - Get Status function.  niarena is correct, you can use the niSwitch Get Relay Position.vi to get the relay's position.
Here's a VI Snippet showing how to get all the relay names and positions for any switch:GetAllRelayPositions.png
Obviously you can simplify it if you already have the relay names you want to check.
(5,072 Views)
Hi marshallg,
Appreciate your quick response. I'll try this and let you guys know. Thanks for the help.
(5,059 Views)
