Switch Hardware and Software
PXI-2584
Regarding the PXI-2584 specs. The sheet says the max channel-ground voltage is 600V ACpk. Would I be able to run 480 Vrms through the channel safely?
Thanks.
(4,640 Views)
Accepted by topic author jangle29
Assuming a pure sine wave, Vpk=Vrms × √2 = 480 × √2 = 679.  So I would say you should not run that through this switch.
(4,586 Views)
