Switch Hardware and Software
Synchronizing CAN card with PXI-2570
Is it possible to synchronize a CAN device (NI-8461) with a  NI Switch device (PXI- 2570) throught the RTSI BUS using Labview? How can I do this?
(6,580 Views)
What kind of synchronization did you have in mind?
Switch modules when set in scanning mode can use a trigger to advance through their scan list and can generate a trigger after each entry in the scanlist. You can read more about scanning and triggering in the NI Switches help under Fundamentals>>Scanning.
Besides being triggered when scanning, switch modules cannot be synchronized.
Guy Ferraro
NI - USA
(6,578 Views)
