05-17-2006 10:08 AM
05-19-2006 12:18 PM
05-24-2006 10:30 AM
05-25-2006
11:38 PM
- last edited on
08-19-2025
11:23 AM
by
Content Cleaner
Hi DY,
If I'm understanding you correctly, during your tests you would like to connect more than one channel to the common. Yes, you can do this with the PXI-2527. You can do this by setting the PXI-2527 topology to Independent and controlling the individual relays in the switch module. For example, if I wanted to connect ch0+,ch0- through ch4+,ch4- to com0+,com0-, I could do this by performing the following relay operations:
ch1 -> pcom0
ch2 -> pcom0
ch3 -> pcom0
pcom0plus -> icom0plus
pcom0minus -> icom0minus
icom0 -> com0
In effect, I'm closing relays:
k0
k1
k2
k3
and opening relays:
KHLSELECT0
KREF0
KCJTEMP
Please reference NI Switches Help>>Devices>>NI PXI-2527>>Independent Topology for more information:
https://www.ni.com/docs/en-US/bundle/ni-switch/page/ni-pxi-pxie-2527.html
Chad PSE
Switch Product Support Engineer
National Instruments - USA
05-25-2006 11:43 PM
A few fixes to the last reply. If I wanted to connect ch0+,ch0- through ch4+,ch4- to com0+,com0-, I also needed to perform the following two relay operations:
ch0 -> pcom0
ch4 -> pcom0
in addition to all those listed above. Also, one additional relay would be closed:
k4
in addition to k0 through k3. OK, that should fix it.
Chad PSE
