We have used the TB-2627 to help development using PXI-2527 switch. We are finished development and want to get rid of the TB-2627 because it protrudes so far out from the PXI chassis. We want to wire directly to a connector that will plug into the 2527 switch and can secure to the 2527 switch. I am looking for a connector that lends itself easily to solder connection and has a strain relief back shell.
The accessory plug recommended on the NI web site is an AMP brand, part number 533285-1. This connector appears to be a PCB mount connector and not for individual wire solder connections or does it lend itself to strain relief.
Can you provide assistance?
David
