Switch Hardware and Software
VISA - com interface
hi
the attached program is used to test switches.
the firsat switch tests properly ( there is communication between the com1 and labview VISA).
but from the 2nd switch ( from loop 3 of the inner sequence), i get a null string.
i am expecting something like HSYNC: 256(when switch2 is at position 1, got it once, but guess missing the timing somewhere bcos the next time its not working)
and i get a null string everytime except for once or twice
pls advice!!
(7,998 Views)
Have you tried using NI-SPY to see where your application is erroring out? If you have never used it before here is a simple tutorial:
NI SPY Tutorial
I would also recommend that if you cannot find the source of your errors that you save the spy log as a .spy file and post it in response to this post. Let me know if that helps.
Logan S.
(7,984 Views)
hi
got the output but getting them in highlight execution mode!!
guess time out problem. how to make the visa read wait until all data is obtained?
ram
(7,979 Views)
There is a property node called "Bytes at Serial Port". You could set up you application to wait until there are a specific number of bytes at the serial port, then perform your reads. That's the easiest option that I can think of.
Logan S.
(7,967 Views)
