Switch Hardware and Software
how to use blutooth client in example s in 7.1
              sir ,
                    sorry for giving invalid information regarding my problem.
         now i am  giving clearly.
                               i am having one file consists of 3000 values(3000 samples of ecg data)
          with the sampling rate of 200 . means that samples are recorded for 15 seconds .
         with the use  of that file  i want to generate  ecg signal  continuously . i want to send the same signal
     to outside, means  connect to external circuits outside the pc. we are having labview 7.1  and daq assistant.
      i need  vi program to solve this problem using DAQ .I AM  attaching that file to message.
         waiting for reply .
        thank you
(6,987 Views)
Hi naraiiiii,
I'm a bit confused since the title of your post mentions the Bluetooth Client Example, but in your post you only discuss DAQ.  If you are looking to output a signal on your hardware, I would suggest look at the DAQmx Analog Output examples in the LabVIEW 7.1 Example Finder (Help>>Find Examples).  Also, there wasn't any attachment to your message.  Did you intend to post your VI?
Best Regards,
Megan B.
(6,978 Views)
