Switch Hardware and Software
switch executiveAPI : get channel name (not alias)
Hi!
Currently working with Switch Executive, I'd like to retrieve the channel names on my IVI Device... All I can get is the Alias (which I don't want)... Is there a way to get the channel name (IVI name or Full name) ??
It seems to be possible to do it through Channel.FormattedName (see NISE Help http://zone.ni.com/reference/en-XX/help/370404G-01/nise/channel_formattedname/), but I can't find FormattedName in my Channel ActiveX property node....
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(6,926 Views)
Accepted by CyGa
Zyl7,
The FormattedName function is an Invoke node function. I would try the following code (LV 2011).
Frank,
Software Group Manager
(6,921 Views)
It looks like I'm going back to the rookie level... Smiley Sad
I've tried everything but that !
Thank you for your fast answer !
(6,910 Views)
