SystemLink Forum
错误-251042发生于 NI Skyline Utilities.lvlib:Parse HTTP Error.vi:5080001
When I run WriteTags.vi in LabVIEWExamples.lvproj, an error occurred.I give a API key in the VI.
Message 1 of 10
(4,703 Views)
I think this post would be useful:
https://forums.ni.com/t5/SystemLink/Error-251042/td-p/3863534
Message 2 of 10
(4,665 Views)
 What version of the SystemLink Client (or more importantly the version of the Tag Support for LabVIEW) do you have installed?
Brandon Grey
Certified LabVIEW Architect
Message 3 of 10
(4,661 Views)
Thanks, I use SystemLink Client 19.0.1,LabVIEW 17.0.160 and NXG Web 3.1.1.
Message 4 of 10
(4,654 Views)
Must I  config systemLink client when I use cloud mode?
Message 5 of 10
(4,652 Views)
I use Evaluation version.
Message 6 of 10
(4,649 Views)
You shouldn't need to configure the SystemLink Client to use the HTTP SystemLink APIs. Where is the error coming from? Is it coming from the Open Configuration? Or is it coming from the Open Tag VIs? Have you checked to make sure that you have the Paths and types correct and that the tags exist on your SystemLink Cloud instance?
Have you tried generating a new API key to see if it's and issue with the API key that you're currently using?
Brandon Grey
Message 7 of 10
(4,630 Views)
I Have tried generating a new API key.How to prove that the API password is correct?The error come from the Open Tag VIs.无标题.png捕获2.PNG
Message 8 of 10
(4,622 Views)
I have created tag on my SystemLink Cloud捕获.PNG.
Message 9 of 10
(4,616 Views)
Can you click into those tags and make sure that they are indeed double tags like you're VI has them configured to be? Also, if we have the type of the Open Tag.VI correct, can you try assigning them a value via the web first to see if that makes a difference?
If you try to use the Open Tag.vi with the wrong type, or on a tag path that doesn't exist (those two are the same thing from the server's perspective), it responds with the same 401 response.
Brandon Grey
Message 10 of 10
(4,601 Views)
