SystemLink Forum
Apply ANP only to one sub folder of a data source
Hello
After creating an ANP in Diadem I wanted to use it on one of our server's folder, but my ANP selected Data source is the whole Server, can I somehow specify to that anp to only work in a designeted sub folder ?
if you have any ideas or solution
thanks
(1,922 Views)
Accepted by Clement_depres
You can define a query for each ANP which allows to narrow down the data used by that ANP - in your case a sub-folder where data is being stored.
To do so enable the Data filter on the Search Query tab.
For the query condition chose the Folder Property on the File level. Specify the sub-folder; don't forget the asterix * at the end...
(1,876 Views)
Hi, exactly what I was looking for, thanks a lot
(1,844 Views)
