SystemLink Forum
Bug report: Exported client configuration dialog box is in German when attempting to import
I exported a client configuration file, then opened it. The result appears as above.
After clicking Nein, I received the following:
Using SystemLink 19.5 with the DataFinder module installed.
(2,544 Views)
Accepted by ChrisStrykesAgain
Hi Christopher,
This is a known localization bug in the software component USI (Universal Storage Interface), which is shared between SystemLink, LabVIEW, DIAdem and other applications.  This will be fixed in the next version.
Thanks for the heads-up,
Brad Turpin
(2,485 Views)
