SystemLink Forum
Error -2147467259 when trying to update package manager on client
I am trying to update the package manager from 18.0.1 to 18.0.2 on a client machine using the SystemLink interface, but I get a Failed (-2147467259) result.  I haven't tried manually updating on the client directly yet as I want to understand the error first. Both the server and client are windows 7 64-bit. See more details below
ARGS:
         "__kwarg__": true,
         "pkgs": [
               "ni-package-manager": "18.0.2.49152-0+f0"
         "refresh": true
         "__kwarg__": true,
         "attr": [
            "description",
            "displayname",
            "displayversion",
            "group",
            "packager",
            "priority",
            "url",
            "uservisible",
            "version"
Detailed Results:
   "Traceback (most recent call last):
File \"C:\\Program Files\\National Instruments\\Shared\\salt\\bin\\lib\\site-packages\\salt\\minion.py\", line 1674, in _thread_multi_return
ret['return'][ind] = func(*args, **kwargs)
File \"C:\\ProgramData\\National Instruments\\salt\\var\\cache\\salt\\minion\\extmods\\modules\
ipkg.py\", line 491, in install
info={'errors': errors, 'changes': ret}
salt.exceptions.CommandExecutionError: Problem encountered installing package(s). Additional info follows:
changes:
errors:
- Conflicting requests.
", false, null ]
(3,829 Views)
Accepted by StephenKM
Currently, SystemLink cannot have NI Package Manager upgrade itself via the Software tab on Managed systems. This is something that we hope to equip SystemLink with the ability to do soon.
Brandon Grey
Certified LabVIEW Architect
(3,799 Views)
Fair enough. But can we at least do a better job of explaining the error. Ideally you could disable this package update from showing up but a least give some meaningful text about the error.  That way I can stop bugging you guys on the forums every time I find another limitation of the current software.
(3,797 Views)
This is a super important capability. Thanks for working on it.
(3,794 Views)
