SystemLink Forum
How does Systemlink licensing work if tester is running on Linux
I have a customer who wants to run a test application on a Linux PC, developed in C/C++.
They are looking into connecting their test system to Systemlink.
We are looking at using the HTTP API as part of their test application to connect to Systemlink and send test results.
Just curious, how does licensing work with this?
1. Obviously systemlink client doesn't run on Linux, so we can't show up in Systemlink as a "system".
2. Is the Test Monitor license on the server side, and therefore will this work ok?
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
(1,186 Views)
Accepted by ChrisFarmerWIS
Yes, the node license is implemented on the server side.
Santhosh
Soliton Technologies
(1,175 Views)
@santo_13 has the correct technical answer.
It's important to also note that even though the Linux system can't have a version of the client installed, it is still considered a node from the point of view of the EULA. This means that a node license needs to be purchased to have that Linux machine communicate with SystemLink via the APIs.
(1,125 Views)
