11-07-2017
09:55 PM
- last edited on
11-03-2025
12:32 PM
by
Content Cleaner
Here's what I've done:
I'm trying to follow http://www.ni.com/documentation/en/systemlink/latest/manual/setting-up-systemlink-client-linux/ but am stuck at Step 3: "On your SystemLink server, use NI MAX to deploy SystemLink Client and any additional software support your application requires to your Linux RT client. "
I can't for the life of me find a way to "use NI MAX to deploy SystemLink Client". I selected Add/Remove Software in NI MAX, but SystemLink isn't in the list of software set add-ons.
Am I looking in the wrong place? How do I deploy SystemLink Client?
Thanks!
Solved! Go to Solution.
11-08-2017 08:48 AM
Relaunch the software installation wizard from MAX for your target. You currently need to do a custom software install to install the SystemLink client to your RT target.
Note we are currently working to add the SystemLink Client as an RSS addon for cRIO in the next release, which should be available in the next month or two.
