06-09-2020 11:46 PM - edited 06-09-2020 11:47 PM
I have a radio Button group like this.
Item: Radio 1 - Value: Value 1
Item: Radio 2 - Value: Value 2
Item: Radio 3 - Value: Value 3
When I run the Dashboard, I would like to pass the selected Item value to a Tag. I try to bind the "Item value" field (on the right side) to a Tag with data type is STRING. However, when I run the dashboard and select an item, it does not pass the item value to the tag.
Please show me how to do that. Thank you in advance.
07-06-2021 09:19 AM
Did you figure out how to do this? I have the same problem.
