01-24-2019 09:25 AM
On the SystemLink Dashboard the only application showing is the Tag Viewer, no file system, test server, or anything else. I've tried reinstalling, than uninstalling completely and reinstalling. License Manager shows SystemLink as licensed. SystemLink Server config shows everything running. Have tried restarting PC, SystemLink Server, and NI Server. Attached is the output from the smconsole command >>PS.
Any thoughts?
Solved! Go to Solution.
01-24-2019 02:05 PM
Are you logging in as an administrator? You may want to open the Web Server Configuration utility to double check the permissions for the various services.
01-24-2019 09:00 PM
Well, that's embarrassing.
08-15-2019 08:17 AM
I'm having the same issue, but my permissions are set for everyone.
