SystemLink Forum
Only Tag Server Showing
On the SystemLink Dashboard the only application showing is the Tag Viewer, no file system, test server, or anything else. I've tried reinstalling, than uninstalling completely and reinstalling. License Manager shows SystemLink as licensed. SystemLink Server config shows everything running. Have tried restarting PC, SystemLink Server, and NI Server. Attached is the output from the smconsole command >>PS.
Any thoughts?
(3,805 Views)
Accepted by topic author ian.yeager
Are you logging in as an administrator?  You may want to open the Web Server Configuration utility to double check the permissions for the various services.
(3,787 Views)
Well, that's embarrassing.
(3,773 Views)
I'm having the same issue, but my permissions are set for everyone.
(3,300 Views)
