SystemLink Forum
Tag database breaks if tag path contains a newline character (SystemLink 2020 R2)
Issue
I programmatically created SystemLink tags in LabVIEW and accidentally included a newline character in the tag path. This seemed to cause problems with the tag database:
  • The newline doesn't get replaced with an underscore, unlike spaces
  • I'm unable to update or delete the tag, even when logged in as administrator. (I can update/delete other tags with "good" names)
Here's what happens if a tag called "Hello\nWorld" is created:
Suggestions
  • Newlines (and all other types of spaces that can be represented in a string) should be replaced by underscores.
  • "Build Path.vi" (or the upstream Salt service?) should sanitise the Minion ID. I had given my CompactRIO a shorter, nicer Minion ID by editing /etc/salt/minion_id. Out of habit, I added an empty line to the end of the file. This was what caused the initial problem.
Questions
So... how do I get rid of the unwanted tag? (Preferably without nuking my whole tag database)
Certified LabVIEW Developer
(1,698 Views)
Accepted by JKSH
@JKSH wrote:
Questions
You should be able to use the LabVIEW API to delete the unwanted tag, or if you're familiar with HTTP APIs, you can access the tag HTTP API directly to delete the tag. The issue appears to be isolated to the web UI disabling the delete button when it shouldn't.
Suggestions
Those are both good suggestions, thank you for reporting this.
(1,658 Views)
