SystemLink Forum
Test Montor API query-results (JSON definition)
When using the API '/nitestmonitor/v1/query-results' function a filter option can be used by adding a JSON format at the 'LabVIEWHTTPclient.vilib:Post.vi' 'buffer' input terminal. Is there more documentation available of the JSON data structure, it is currently not described in the 'Test Monitor Web Service API.pdf'?
(3,463 Views)
Accepted by Coert
Here is a link to the Swagger documentation for the Test Monitor API.
https://github.com/ni/systemlink-OpenAPI-documents/tree/master/test-monitor
To view the documentation, just paste the yml contents into editor.swagger.io.
(3,450 Views)
Hi Joshua,
Thank you for the tip! Very useful, also Swagger was new for me!
Kind regards,
Coert Ansems
(3,442 Views)
