SystemLink Forum
Uninstall LabVIEW NXG 1.0 or others
It's probably not the best forum, but I could think of another in relation to the packager manager.
I was looking how to install NXG 1.0 without disrupting other installations of NXG.
The screen shot shows 3 entries for LabVIEW NXG, one of which is 1.0 (it's in fact version 4.9.3.49152-0+f0).
1. I think it would great if we could see the NXG version 1.0, 2.1, 3.0 from the name of the "Programming environment" package entry.
Other that that I found it a bit scary to select remove, because I didn't know what it would take along with it.
2. Is it permissible to remove the additional language packs without corrupting the NXG installation?
André (CLA, CLED)
(4,020 Views)
I'm not as familiar with LabVIEW NXG versioning but do you have the "Show full version numbers and hidden packages" item checked in the NIPM settings?
If you uncheck that, do you see the version change back to something more human readable?
As for your question about removing langauage packs, I'm not sure I know the answer to that.
Brandon Grey
Certified LabVIEW Architect
(4,008 Views)
Unchecking shows my the baseline versions, strange that they can't show both when it's checked.
André (CLA, CLED)
(3,982 Views)
