The Daily CLAD
Community Browser
Re: 2D Array to String
SercoSteveB
Active Participant
What is String Out following execution of the VI?
Comments
VSC
The resultant of the diagram above is C.
MrStevenUND
Ans: C.  Tricky.  I didn't notice the 2D array right away.
nmpundlik
Ans is C.
crossrulz
Knight of NI
New rows cause end of lines.  Answer is C
Asha_Nagaraj
Ans is C
LordNobady
C
Learning LabVIEW since January 2013
RAMESHB
Answer is C
adiveppa
Answer ic C
Kumarhatti
ANS :C
sumapatil
Answer is C
jagadishj
The answer is C because of using 2D array to string constant.
SercoSteveB
Active Participant
Answer: C.  Nice one VSC, MrStevenUND, nmpundlik, crossrulz, Asha_Nagaraj, LordNobady, RAMESHB, adiveppa, Kumarhatti, sumapatil & jagadishj
The biggest list of correct answertees for a while, the questions are obviously way to easy.
mini09
Active Participant
C as well....
Joseph.Vitale
C. Now what would happen if the left top was not left blank.
ashwinilele
C
