Identify the Array Nodes shown below?
a) 1=Insert Into Array, 2=Replace Array Subset, 3=Delete From Array, 4=Array Subset
b) 1=Replace Array Subset, 2=Insert Into Array, 3=Delete From Array, 4=Array Subset
c) 1=Replace Array Subset, 2=Insert Into Array, 3=Array Subset, 4=Delete From Array
d) 1=Insert Into Array, 2=Replace Array Subset, 3=Array Subset, 4=Delete From Array
