What are the contents of 'Search Position Out' following execution of the VI?
The other case for the case structure used in the question is shown below:
a) A 1D Array containing {-1,-1}
b) A 1D Array containing {0,0}
c) A 1D Array containing {0,1}
d) A 1D Array containing {1,0}
