Which of the following most closely matches the function of the block diagram symbol?
Symbol enlarged.
a) Displays the next object in the tab order on the Block Diagram
b) Allows you to attach a Free Text Label to a Block Diagram object
c) Is displayed when dragging a dropping Block Diagram object
d) Click on this symbol to resize a Block Diagram object
