What behaviour will LabVIEW exhibit if the user selects the Step Over
button on the following Block Diagram?
a) Nothing
b) The VI will execute
c) The VI will execute and pause at the Addition node
d) The VI will execute and pause at either the Numeric Value In 1 or Numeric Value In 2 Control
