The Daily CLAD
Community Browser
Re: Build Cluster Array
SercoSteveB
Active Participant
What are the contents of Array Out following execution of the VI?
Comments
crossrulz
Knight of NI
A
MrStevenUND
A is closest to what I was thinking it should be.
Not applicable
A
nik35324
A
LordNobady
A
Learning LabVIEW since January 2013
kavyanaresh
Ans: A
Thanks for posting different models of Questns.....
These will help to improve myself......Thanks Steve.....
mini09
Active Participant
A
yash06
A
heavypoet
A
Ihab
A
beautyandbrains
A
SercoSteveB
Active Participant
ramesh44
My doubt here is when I Ran this Code it is taking Numeric 3 has label for the output cluster but in answer its numeric1 is given what may be the reason why i am not getting Numeric1
crossrulz
Knight of NI
It appears to use the label of the source going into the bottom terminal as the label for the item in the cluster.
But for this question, worry more about the data.  Besides, you can always change the label in the indicator.
