What are the contents of Boolean Array Out following execution of the VI?
A
A. You can't replace an array element that isn't there.
Answer: A. Nice one Jsoni, MrStevenUND, crossrulz, nik35324, heavypoet, LordNobady, P@Anand, gnshmrthy & fabert.
As MrStevenUND points out, you cannot replace an element that does not exist.
